[Bug 1206] __RTEMS_REVISION__ broken in all rtems versions
rtems-bugs at rtems.org
Tue Jan 2 08:30:13 CST 2007
http://www.rtems.org/bugzilla/show_bug.cgi?id=1206
jwillemsen at remedy.nl changed:
What |Removed |Added
Severity|enhancement |minor
Summary|Now possible to check for |__RTEMS_REVISION__ broken in
|micro number |all rtems versions
------- Comment #1 from jwillemsen at remedy.nl 2007-01-02 08:30 -------
On the mailing list I got back that I could use __RTEMS_REVISION__ but this is
broken, so changing this bugzilla bug to get __RTEMS_REVISION__ fixed
Configure bugmail: http://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You reported the bug, or are watching the reporter.
More information about the rtems-bugs
