[Bug 1211] Wrong file locations prevent sucessful build for PowerPC + workaround
rtems-bugs at rtems.org rtems-bugs at rtems.org
Tue Jan 9 08:41:50 CST 2007
http://www.rtems.org/bugzilla/show_bug.cgi?id=1211
------- Comment #15 from rsg at alum.mit.edu  2007-01-09 08:41 -------
(In reply to comment #14)
> (In reply to comment #13)
> > (In reply to comment #12)
> > Hi Ralf,
> > I did indeed have 1.9.6 of automake.  I installed 1.10 and tried your
> > instructions, but the same failures result.
> Check the first couple of lines of your c/src/lib/libcpu/powerpc/Makefile.in
> if it referrs to automake-1.9.6 or automake-1.10
Okay, I tried this from a fresh untar of rtems-4.6.99.3.tar.bz2; this archive I
downloaded last month, and is dated 2006/04/24.  When I check the file you
mentioned, it does indeed have this as its first line:
# Makefile.in generated by automake 1.9.6 from Makefile.am.
So this seems to be a problem in the tarball?  Unfortunately, I don't have
access to the RTEMS CVS from here, behind the firewall, so I'm kind of stuck
with the tarball I have.  I decided to go forward, and the bootstrap procedure
give many messages I had not seen before (with automake 1.9.6); before, it was
pretty quiet.  Here are the first few lines of the output:
$ ./bootstrap
./c
./c/src/ada-tests
./c/src
/usr/share/automake-1.10/am/depend2.am: am__fastdepCCAS does not appear in
AM_CONDITIONAL
/usr/share/automake-1.10/am/depend2.am:   The usual way to define
`am__fastdepCCAS' is to add `AM_PROG_AS'
/usr/share/automake-1.10/am/depend2.am:   to `configure.ac' and run `aclocal'
and `autoconf' again.
./c/src/lib/libbsp/arm/armulator
AM_CONDITIONAL
acinclude.m4 is unchanged
In summary, I'm getting a lot of "XXX.m 4 is unchanged" and "am_fastdepCCAS
does not appear in AM_CONDITIONAL" messages.  I'm hoping this raises a flag in
your mind as to what is going on...
Thanks, Ralf!
> Also make sure to have removed all autom4te.caches before running ./bootstrap
> (Running ./bootstrap -c before ./bootstrap does this).
I did that exact command.
> Also start with an empty build directory.
Tried that too.
Configure bugmail: http://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
You reported the bug, or are watching the reporter.
More information about the rtems-bugs mailing list
