[Bug 567] Both BSP and controller-specific probes should be invoked
bugzilla-daemon at rtems.org
Tue Aug 5 12:28:42 CDT 2008
http://www.rtems.org/bugzilla/show_bug.cgi?id=567
Joel Sherrill <joel.sherrill at oarcorp.com> changed:
What |Removed |Added
CC| |joel.sherrill at oarcorp.com
AssignedTo|jennifer.averett at oarcorp.com|chrisj at rtems.org
Status|ASSIGNED |NEW
Platform| |All
Target Milestone|--- |4.9
In the function ide_controller_initialize, file
c/src/libchip/ide/ide_controller.c, controller-specific
probe not called if BSP-specific probe function provided and returns TRUE. I
beleive this is not correct. In my opinion,
both BSP-specific and IDE controller driver-specific
probes should return TRUE if both of them provided.
Release:
RTEMS-4.6
--- Comment #1 from Victor V. Vengerov <vvv at oktetlabs.ru> 2004-02-02 03:12:00 ---
Fix:
Patch is attached.
--- Comment #2 from Joel Sherrill <joel.sherrill at oarcorp.com> 2008-08-05 12:28:41 ---
Chris, this is a simple patch. Do you think it should be applied?
Configure bugmail: http://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug.
More information about the rtems-bugs
