[Bug 1593] RTEMS Sequenced Initialization API
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Tue Jul 27 02:26:24 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1593
--- Comment #20 from Sebastian Huber <sebastian.huber at embedded-brains.de> 2010-07-27 02:26:20 CDT ---
(In reply to comment #19)
> This comment has the word "create" spelled as "creat".  More important than
> that is that it duplicates a description of the mechanics of what is happening.
Yes, these bloat comments should be removed completely.
> When this is committed, will EVERY linkcmds have to be modified or that BSP
> break?
The first patch will not break existing BSPs.  Only the test case will lead to
a linker error.  The next step is to modify every linker command file.
Afterwards we have to make sure that every BSP can compile and link the test
case.  After this we can change the actual manager initialization procedure.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
