[Bug 1638] tar01/tar02 tarballs contain non-deterministic uids/gids + permissions
bugzilla-daemon at rtems.org
Thu Jul 29 01:54:12 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1638
Chris Johns <chrisj at rtems.org> changed:
What |Removed |Added
CC| |chrisj at rtems.org
--- Comment #3 from Chris Johns <chrisj at rtems.org> 2010-07-29 01:54:11 CDT ---
(In reply to comment #2)
> That said, at present, I am leaning towards adding binary tarballs with
> predefined uids/gids/permissions and not to user-generate them.
If we are converting the binary tar file to a C file should we just commit the
C file ?
I am not sure if this approach can be extended to all RTEMS applications. I
know with Parrot we need to create a base file system at the build time to
capture the host compiled byte code files. I wonder if the building of the test
Parrot application should fail if a no suitable tar can be found on the build
host. Ralf, I would appreciate your feed back on this issue.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
