[Bug 1642] Coverage Improvement: imfs routines
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Fri Jul 30 10:43:04 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1642
--- Comment #8 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-07-30 10:43:04 CDT ---
These modifications result in the test ending in an internal error for me.
If that is intentional, then the fatal error case needs to be moved to
a new test with "fatal" in the name so the test scripts can handle it
properly.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
