[Bug 1556] New: rfs type efs violate type naming conventions
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Mon Jun 14 09:13:27 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1556
           Summary: rfs type efs violate type naming conventions
           Product: RTEMS
           Version: 4.10
          Platform: All
        OS/Version: RTEMS
            Status: NEW
          Severity: blocker
          Priority: P3
         Component: cpukit
        AssignedTo: joel.sherrill at oarcorp.com
        ReportedBy: ralf.corsepius at rtems.org
                CC: chrisj at rtems.org
The rfs code applies this kind of typedefs
typedef struct xxxx_t {
} xxxx;
This violates the conventions POSIX and RTEMS apply on types' naming:
*_t is meant to be a typedef.
i.e. these typedefs are *all* reversed and should be renamed such that the *_t
are the typedefs.
Proposal: drop the structs and use typedefs only, i.e.
typedef struct {
} xxx_t;
Alternatively
typedef struct xxxx_s {
} xxx_t;
I haven't checked it this also affects rtems-4.10, but marking this as a
blocker bug for 4.10 until this has been verified.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
