[Bug 1546] Coverage improvement: fifo_open
bugzilla-daemon at rtems.org
Wed Jun 16 14:01:09 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1546
--- Comment #10 from Joel Sherrill <joel.sherrill at oarcorp.com> 2010-06-16 14:01:07 ---
There is an issue with spfifo06.
Read task activated, sleeping to block the writer
Now, reader opening file(1)
/home/joel/test-gcc/rtems/c/src/../../testsuites/sptests/spfifo06/test.c: 48 fd
> 0
Also.. please don't use so many blank lines in the output. Some targets use
LCDs and that makes the test output of interest disappear too quickly.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
