[Bug 1546] Coverage improvement: fifo_open
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Thu Jun 24 03:10:15 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1546
Bharath Suri <bharath.s.jois at gmail.com> changed:
           What    |Removed                     |Added
 Attachment #773 is|0                           |1
           obsolete|                            |
 Attachment #796 is|0                           |1
           obsolete|                            |
--- Comment #11 from Bharath Suri <bharath.s.jois at gmail.com> 2010-06-24 03:10:11 CDT ---
Created an attachment (id=817)
 --> (https://www.rtems.org/bugzilla/attachment.cgi?id=817)
Contains spfifo01, spfifo02 and spfifo03 for rtems/testsuites/sptests
The attachment contains spfifo01, spfifo02 and spfifo03 for
rtems/testsuites/sptests.
rtems/testsuites/ has spfifo*. All of these need to be replaced with the
contents of this attachment containing 3 tests.
These tests would fail / not yield intended results without the patches for PR
1542 and PR 1585.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
