[Bug 1595] psxtests/psximfs01/init.c: bad code
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Wed Jun 30 09:09:12 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1595
--- Comment #2 from Ralf Corsepius <ralf.corsepius at rtems.org> 2010-06-30 09:09:11 CDT ---
(In reply to comment #1)
> There was no warning on the target I used to develop this test.
Which architecture did you use?
In my understanding, gcc should warn about printing [s]size_t's with %d
dependently of the architecture. May-be my understanding is incorrect and it
only warns if a [s]size_t's size doesn't match "int" sizes.
> Which architecture shows this? I would like to check the fix.
pc586 BSP from an unmodified rtems-CVS HEAD as of this morning w/ original
i386-rtems4.11-gcc*rpms.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
