[Bug 1521] Change mount to be like the Linux mount.
bugzilla-daemon at rtems.org
Fri May 21 02:11:00 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1521
--- Comment #4 from Chris Johns <chrisj at rtems.org> 2010-05-21 02:10:54 ---
Thanks Till. I have moved the gethostbyname into the build IP address call.
This change has removed the cruft from the shell where there was a need to
provide specific handlers for each file system. It also means the fsmount code
can be simpler. I have changed the struct names in this code to match the mount
call and so will break applications that use this. I think the end result will
be better. This is a heads up about this. The release notes will need a
comment.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
