[Bug 1286] [imfs] cannot access long filenames in directory mounted on IMFS mountpoint
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Sat May 29 00:05:42 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1286
Chris Johns <chrisj at rtems.org> changed:
           What    |Removed                     |Added
             Status|NEW                         |ASSIGNED
                 CC|                            |chrisj at rtems.org
         AssignedTo|joel.sherrill at oarcorp.com   |chrisj at rtems.org
--- Comment #1 from Chris Johns <chrisj at rtems.org>  2010-05-29 00:05:38 ---
The fix is to perform the test for a mounted file system when changing
directory and not to loop and call the token handler. If the new directory is a
mount point we should pass off to that file system the remainder of the path.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
