[Bug 1712] Add LWIP Support to RTEMS
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Tue Nov 2 05:37:41 CDT 2010
https://www.rtems.org/bugzilla/show_bug.cgi?id=1712
--- Comment #7 from Sebastian Huber <sebastian.huber at embedded-brains.de> 2010-11-02 05:37:40 CDT ---
(In reply to comment #6)
> (In reply to comment #5)
> > (In reply to comment #4)
> > > (In reply to comment #1)
> > > Nothing that I am aware about qualifies LWIP to be close to "a standard
> > > solution". To me, it's yet another more or less complete IP stack, not more and
> > > not less.
> > > Also, from a project maintainer's view, adding a second IP stack is a
> > > maintenance nightmare - Something I am not by any means keen on to support.
> > Targets with 256k ROM and 64k RAM will not work with the BSD stack.  It is also
> > easier to implement real time processing with lwIP due to its low stack
> > complexity.
> This is valid and I understand the use case but does that mean we need to add
> the stack to RTEMS. Can it be a separate package and maintained as such ? Can
> the RTEMS support be added to LWIP and it be built for RTEMS ?
> My main concern is maintenance of RTEMS. Any networking code outside of
> libnetworking will break unless it becomes conditional on the type of
> networking stack. It adds another variant we need to build and test and provide
> coverage of.
The lwIP project has already an area for ports
http://cvs.savannah.gnu.org/viewvc/contrib/ports/?root=lwip
in their CVS.  We can use this.  It is also good from an advertising point of
view to get RTEMS visible here.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
