[Bug 1979] Milkymist: Handle MIDI framing in the interrupt handler
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Sun Dec 4 16:47:50 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1979
--- Comment #2 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-12-04 16:47:49 CST ---
Nice change.  Since you already had the message queue, for this little bit of
work in the ISR, you save a lot of overhead.
Looks good to me.
Out of curiousity, how are these features in the BSP and their application
configuration requirements documented?  This is not a criticism but an open
issue for RTEMS in general.  In my head, it makes sense for each BSP to provide
a document fragment in a defined format and style that can be picked up by a
master document.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
