[Bug 1841] Incorrect processing of DNS info from DHCP
bugzilla-daemon at rtems.org
Wed Dec 7 09:00:50 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1841
--- Comment #9 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-12-07 09:00:27 CST ---
(In reply to comment #8)
> (In reply to comment #7)
> > Yes, leave it where it is. Thinking a little more about this we cannot reset
> > the value to 0. The correct solution is to track static and DHCP entries and
> > remove only the DHCP entries when a new request is received.
> Unless this is done properly, can we simply reset it at the beginning of a new
> request? I believe this already represents a progress for most configurations,
> including mine.
Give me a line number or good hint at where it needs to go.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
