[Bug 1984] CONFIGURE_MINIMUM_STACK_SIZE vs CONFIGURE_MINIMUM_TASK_STACK_SIZE
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Wed Dec 7 14:12:43 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1984
Joel Sherrill <joel.sherrill at oarcorp.com> changed:
           What    |Removed                     |Added
             Status|NEW                         |RESOLVED
         Resolution|                            |FIXED
--- Comment #3 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-12-07 14:12:43 CST ---
(In reply to comment #2)
> This is fine. I still am not convinced the default behavior of propagating
> user-defined CONFIGURE_MINIMUM_STACK_SIZE to the idle stack size and the
> interrupt stack size is a good idea, considering there are specific CONFIGURE
> macros for overriding those.
It is worth discussing but the documentation was simply wrong. :)
We can make a decision on your suggestion and change it separately.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
