[Bug 1992] HTML output error
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Wed Dec 14 12:39:21 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1992
Ralf Corsepius <ralf.corsepius at rtems.org> changed:
           What    |Removed                     |Added
                 CC|                            |ralf.corsepius at rtems.org
--- Comment #5 from Ralf Corsepius <ralf.corsepius at rtems.org> 2011-12-14 12:39:19 CST ---
(In reply to comment #3)
> (In reply to comment #2)
> > The texi2html version 1.82 doesn't have this problem.
> And is running Fedora 14.  It is due for an upgrade.
I checked Fedora's sources.
The f14, f15, 16 versions of texi2html are more or less identical (Only the
rpm's release number differ, the rest is identical).
=> Should there be anything Fedora release-specific, then it's not inside of
the texi2html package but somewhere in its surroundings.
FWIW: I am seeing the same extra bullet with my F16 built docs.
(In reply to comment #4)
> This machine uses openSUSE 11.2 (x86_64).
Even more interesting ;)
Though openSUSE has texi2html in its build service, they don't ship texi2html
as part of the distro. The tarballs inside of their build service's rpms'
sources are identical to Fedora's, even the spec file is "derived" from Fedora
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
