[Bug 1997] GCC PR 38644
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Tue Dec 20 22:31:49 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1997
--- Comment #2 from Ralf Corsepius <ralf.corsepius at rtems.org> 2011-12-20 22:31:47 CST ---
(In reply to comment #0)
> A bug fix for PR 38644 is in the GCC 4.6 branch, but not in the current RTEMS
> version.  It would be nice if we can add this fix to the GCC patch.
> http://gcc.gnu.org/viewcvs?view=revision&revision=181406
Well, AFAIS, this patch is not in gcc-4_6-branch, but on somebody's
semi-official "ARM/embedded-4_6-branch" development branch and on gcc-trunk.
As I do not want to start mixing branches with unclear outcome and to
potentially get lost in followups, I prefer not to apply this patch.
Instead, I'd recommend you "to talk upstream GCC into"/"persuade upstream GCC
to" adding this patch to gcc-4_6-branch.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
