[Bug 1729] SMP Step #2
bugzilla-daemon at rtems.org
Wed Feb 2 13:50:36 CST 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1729
--- Comment #16 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-02-02 13:50:34 CST ---
(In reply to comment #15)
> Some more detailed comments.
> * c/src/lib/libbsp/shared/smp/smp_stub.c
> +#include <rtems/bspsmp.h>
> +#include <stdlib.h>
> double include.
Jennifer will fix.
> * Why move sparc/cpu_irq.S into libbsp/sparc/shared?
Because reading the cpu id is not defined as part of v7/v8 but by the leon3
implementation.
> * cpukit/score/cpu/sparc/cpu_asm.S: _CPU_Context_switch_to_first_task_smp
> The comment states it may not be safe to flush windows, but proceeds to issue a
> window save. Is this considered safe, or should the window save be done after
> setting up the WIM and before branching to done_flushing?
> * cpukit/score/include/rtems/bspsmp.h
> why are some functions prefaced with rtems_bsp_smp_xx, others with bsp_smp_xxx
> typos: will reschedule on this this CPU -- "this" repeated twice. Happens in
> multiple lines in bspsmp.h
Jennifer will fix.
> void bsp_smp_broadcast_message(): should this function issue IPIs to EVERY cpu?
> including the originating cpu?
not including the originating (as you noticed) because you already
know what happened. Jennifer add this to the Doxygen comments.
> What is the difference between bsp_smp_broadcast_message() and
> bsp_smp_interrupt_cpu()?
I think you missed that there are 4 methods.
+ bsp_smp_send_message
+ bsp_smp_broadcast_message
+ bsp_smp_broadcast_interrupt
+ bsp_smp_interrupt_cpu
You can send a message to one or all other CPUs. And interrupt
Jennifer.. the "XXX_message" ones are rtems_smp and are part of the Score SMP
handler. So probably really should be _SMP_Send_message and
_SMP_Broadcast_message. This means more content for
score/include/rtems/score/smp.h
The "XXX_interrupt" should be bsp_XXX to indic
> Is it usual to have such an interface defined in the score that relies so
> heavily on BSP functions?
It is not particularly common but there are other cases.
The precedences I can think of are the nanoseconds since last tick extension
and MPCI BSP support. The clock tick extension was an indirect call but
Sebastian made it a weak symbol. I want to get it to being a known name which
the BSP has to provide. The MPCI stuff could eventually be a known name also.
Known names which the BSP has to provide as easier to explain and document.
This is why the BSP framework went this way.
> Can we extend the existing uni-processor interfaces
> to support the notion of cpu id? Are these functions implemented per-BSP, or
> generically at the SCORE level? If generically, they should probably belong to
> an SMP handler?
This is how we are testing it now BUT as mentioned earlier, it adds overhead
both in execution time and space. When the code is completely in, we can
discuss it again but I think the SMP overhead will always be too much to want
to treat a small single CPU system as a single core SMP system.
There does need to be a Score SMP handler for other things though.
> * cpukit/score/include/rtems/score/percpu.h
> + /** This element is used to lock this structure */
> + SMP_lock_control Lock;
> Why capital L in Lock? This is inconsistent with structure field names.
Usually caps in structures are reserved for substructures. So this
should be lower.
> Do we know that uint32_t is the best choice of data size for IPI payloads
> (state, message) and lock_control? Or should these be BSP-dependent types?
No but we don't know it isn't. :)
This could be overridden on a per target basis but not a per BSP basis if the
need arises.
> + * @brief Initialize SMP Handler
> + * This method initialize the SMP Handler.
> +void _SMP_Handler_initialize(void);
> Are there multiple handlers defined in this header file? Should there be a
> separate SMP handler that instantiates all of these SMP-related files?
> It seems a lot of the #ifdef's can be eliminated by defining the uni-processor
> RTEMS as an SMP system with 1 CPU having id=0. Then the same arrays can be used
> and identical initializing and updating code. This simplify a lot of other
> files, such as confdefs.h, threadcreateidle.c, and probably others.
Yes but see above for overhead in time and space.
Worth evaluating when this all works and we have hard numbers on time
and space. Committing to that now is too early.
> * cpukit/score/include/rtems/score/smplock.h
> Should it be SMP_Lock_control, or SMP_lock_Control, or SMP_lock_control? And
> previously mentioned the volatile keyword.
SMP_lock_Control
Class is SMP_lock. Element is Control.
> * cpukit/score/src/smp.c
> + * This is definitely a hack until we have SMP scheduling. Since there
> + * is only one executing and heir right now, we have to fake this out.
> Can you identify what will go here when there is a proper scheduler?
Not near as much as is hacked in now. LOL
Disable context switching
_CPU_Context_switch_to_first_task_smp( &heir->Registers );
> + * HACK: Should not have to enable interrupts in real system here.
> + * It should happen as part of switching to the first task.
> Will this be moved somewhere else then?
Switching to the first task on each of the cores will enable interrupts.
So we are just hacking now to prove we can get the cores to do something.
> rtems_smp_process_interrupt():
> + while(1)
> + /* does not continue past here */
> Is there a better way to do this, like a BSP-defined "halt"? This will make
> sense for example on platforms with the ability to shutdown cores for reducing
> power.
Yes. That is certainly an option. Perhaps a bsp_shutdown_core() or something
similar.
> + printk( "switch needed\n" );
> Debug statement?
Yes. pretty much everything you are going through is a rough approximation of
the initialization but since we don't have an smp scheduler, we don't really
have threads allocated as heir to each of the cores.
> + if ( cpu == dest_cpu )
> + continue;
> I guess this answers the question about broadcasting to the source. This should
> be clearly documented.
Agreed.
> + bsp_smp_broadcast_interrupt();
> Might be better to notify while sending the message? Acquiring locks can be
> quite expensive.
But we have to send the message to all CPUs before we tell them it is
there.
Are you suggesting we ignore a broadcast interrupt capability
and send an individual interrupt while sending each message?
> * cpukit/score/src/smplock.c
> This implements a spin lock. There are many types of locks (e.g. R/W locks,
> RCU, and so on). The naming should be more precise and forward compatible in
> case additional locks are implemented.
SMP Spin Lock? Or do you have something in mind?
> * cpukit/score/src/thread.c:
> -/*PAGE
> -#if defined(RTEMS_MULTIPROCESSING)
> - _Thread_MP_Handler_initialization( maximum_proxies );
> -#endif
> + #if defined(RTEMS_MULTIPROCESSING)
> + _Thread_MP_Handler_initialization( maximum_proxies );
> + #endif
> These syntactical fixes are distracting. Just a nit for the future.
Jennifer .. I can comment some of these separately. I thought most of them
were out.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
