[Bug 1854] RBTree test: sprbtree01 test includes rtems_rbtree_extract testing
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Tue Jul 26 13:46:00 CDT 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1854
--- Comment #4 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-07-26 13:46:00 CDT ---
I suspect it is corrupting some memory.  But I tried increasing the stack and
printing a stack usage report.  That is not the issue.
I checked use of node_array and the new code doesn't appear to over-index it.
Double check me on that.
Then binary search by disabling all new test cases except one until you narrow
it down.  It is only a few cases so that should get us down to just a few lines
of code. :D
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
