[Bug 1765] RTEMS Toolset Patch for ARM EABI version 5
bugzilla-daemon at rtems.org
Sat May 21 10:01:22 CDT 2011
https://www.rtems.org/bugzilla/show_bug.cgi?id=1765
--- Comment #6 from Joel Sherrill <joel.sherrill at oarcorp.com> 2011-05-21 10:01:21 CDT ---
(In reply to comment #5)
> The edb7312 BSP passes all RTEMS tests on Skyeye simulator.
> GCC C and C++ test suite results for edb7312 BSP on Skyeye simulator:
> === gcc Summary ===
> # of expected passes 72588
> # of unexpected failures 201
> # of unexpected successes 7
> # of expected failures 183
> # of unresolved testcases 138
> # of unsupported tests 1106
> === g++ Summary ===
> # of expected passes 25625
> # of unexpected failures 10
> # of unexpected successes 1
> # of expected failures 162
> # of unsupported tests 427
These are much better than the ELF based toolset gets.
When RPMs are available to test, please let me know.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
