[Bug 2050] New: xkt564levb fails to build
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Tue Apr 3 08:53:23 CDT 2012
https://www.rtems.org/bugzilla/show_bug.cgi?id=2050
             Bug #: 2050
           Summary: xkt564levb fails to build
    Classification: Unclassified
           Product: RTEMS
           Version: HEAD
          Platform: All
        OS/Version: RTEMS
            Status: NEW
          Severity: normal
          Priority: P3
         Component: bsps
        AssignedTo: joel.sherrill at oarcorp.com
        ReportedBy: ralf.corsepius at rtems.org
The xkt564levb fails to build with gcc-4.7.0 and multilibs enabled:
gmake[5]: Entering directory
`/users/rtems/src/rtems.org/rtems.mirror/BUILD/powerpc-rtems4.11/c/xkt564levb/lib/libbsp/powerpc/mpc55xxevb'
powerpc-rtems4.11-gcc --pipe -B../../../../../.././lib/
-B../../../../../.././xkt564levb/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
 -isystem ../../../../../.././xkt564levb/lib/include   -mcpu=8540 -meabi
-msdata -fno-common -msoft-float -D__ppc_generic -mstrict-align -O2 -g
-fno-keep-inline-functions -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
smsc9218i.o -MD -MP -MF .deps/smsc9218i.Tpo -c -o smsc9218i.o `test -f
'network/smsc9218i.c' || echo
'../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/'`network/smsc9218i.c
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:
In function 'smsc9218i_interrupt_handler':
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:637:6:
error: 'SIU_tag' has no member named 'EISR'
In function 'smsc9218i_new_mbuf':
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:763:3:
warning: variable 'ms' set but not used [-Wunused-but-set-variable]
In function 'smsc9218i_compact_frame':
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:960:3:
In function 'smsc9218i_interrupt_init':
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1517:9:
error: variable 'direr' has initializer but incomplete type
error: unknown field 'R' specified in initializer
warning: excess elements in union initializer [enabled by default]
warning: (near initialization for 'direr') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1517:23:
error: storage size of 'direr' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1518:9:
error: variable 'dirsr' has initializer but incomplete type
warning: (near initialization for 'dirsr') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1518:23:
error: storage size of 'dirsr' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1519:9:
error: variable 'orer' has initializer but incomplete type
warning: (near initialization for 'orer') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1519:22:
error: storage size of 'orer' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1520:9:
error: variable 'ireer' has initializer but incomplete type
warning: (near initialization for 'ireer') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1520:23:
error: storage size of 'ireer' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1521:9:
error: variable 'ifeer' has initializer but incomplete type
warning: (near initialization for 'ifeer') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1521:23:
error: storage size of 'ifeer' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1522:9:
error: variable 'idfr' has initializer but incomplete type
warning: (near initialization for 'idfr') [enabled by default]
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1522:22:
error: storage size of 'idfr' isn't known
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1541:16:
error: 'SIU_tag' has no member named 'DIRSR'
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1545:6:
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1550:15:
error: 'SIU_tag' has no member named 'ORER'
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1552:6:
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1571:15:
error: 'SIU_tag' has no member named 'IDFR'
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1573:6:
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1577:6:
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1581:16:
error: 'SIU_tag' has no member named 'DIRER'
../../../../../../../../c/src/lib/libbsp/powerpc/mpc55xxevb/network/smsc9218i.c:1583:6:
warning: unused variable 'idfr' [-Wunused-variable]
warning: unused variable 'ifeer' [-Wunused-variable]
warning: unused variable 'ireer' [-Wunused-variable]
warning: unused variable 'orer' [-Wunused-variable]
warning: unused variable 'dirsr' [-Wunused-variable]
warning: unused variable 'direr' [-Wunused-variable]
gmake[5]: *** [smsc9218i.o] Error 1
gmake[5]: Leaving directory
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
