[Bug 2012] mdump and wdump shell cmds handle length arg incorrectly; add ldump cmd
bugzilla-daemon at rtems.org bugzilla-daemon at rtems.org
Thu Feb 2 15:11:32 CST 2012
https://www.rtems.org/bugzilla/show_bug.cgi?id=2012
Joel Sherrill <joel.sherrill at oarcorp.com> changed:
           What    |Removed                     |Added
             Status|NEW                         |RESOLVED
         Resolution|                            |FIXED
--- Comment #12 from Joel Sherrill <joel.sherrill at oarcorp.com> 2012-02-02 15:11:31 CST ---
Thanks.
http://git.rtems.org/rtems/patch/?id=bcd065cc16aa15c35f59618673220f6dc5504af7
is the diff of the change as a set.
It would have looked very similar when we were using CVS. The important thing
is that it is a diff with changes to multiple files. Much easier to apply
without potential problems.
Please check out RTEMS with the changes and make sure they look good to you.
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs mailing list
