[Bug 2042] arm-rtemseabi: multilibs don't build
bugzilla-daemon at rtems.org
Tue Mar 27 08:34:37 CDT 2012
https://www.rtems.org/bugzilla/show_bug.cgi?id=2042
--- Comment #1 from Ralf Corsepius <ralf.corsepius at rtems.org> 2012-03-27 08:34:37 CDT ---
Another similar breakdown:
gmake[8]: Entering directory
`/users/rtems/src/rtems.org/rtems.mirror/BUILD-arm-eabi-4.7.0/arm-rtemseabi4.11/thumb/armv6-m/cpukit/score/cpu/arm'
arm-rtemseabi4.11-gcc --pipe -mthumb -march=armv6-m --pipe -DHAVE_CONFIG_H
-I../../.. -I../../../../../../lib/include -g -O2 -Wall
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -mthumb
-march=armv6-m -MT libscorecpu_a-armv7m-context-restore.o -MD -MP -MF
.deps/libscorecpu_a-armv7m-context-restore.Tpo -c -o
libscorecpu_a-armv7m-context-restore.o `test -f 'armv7m-context-restore.c' ||
echo '../../../../../../../../cpukit/score/cpu/arm/'`armv7m-context-restore.c
mv -f .deps/libscorecpu_a-armv7m-context-restore.Tpo
.deps/libscorecpu_a-armv7m-context-restore.Po
-march=armv6-m -MT libscorecpu_a-armv7m-context-switch.o -MD -MP -MF
.deps/libscorecpu_a-armv7m-context-switch.Tpo -c -o
libscorecpu_a-armv7m-context-switch.o `test -f 'armv7m-context-switch.c' ||
echo '../../../../../../../../cpukit/score/cpu/arm/'`armv7m-context-switch.c
../../../../../../../../cpukit/score/cpu/arm/armv7m-context-switch.c: In
function '_CPU_Context_switch':
../../../../../../../../cpukit/score/cpu/arm/armv7m-context-switch.c:30:3:
warning: asm operand 0 probably doesn't match constraints [enabled by default]
warning: asm operand 1 probably doesn't match constraints [enabled by default]
warning: asm operand 2 probably doesn't match constraints [enabled by default]
error: impossible constraint in 'asm'
gmake[8]: *** [libscorecpu_a-armv7m-context-switch.o] Error 1
Configure bugmail: https://www.rtems.org/bugzilla/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are watching all bug changes.
More information about the rtems-bugs
